48v to 24v PoE converter?
Has anyone ever used such a device? I ordered a set, because it could fix a solar camera system issue I’ve been dealing with, (mainly due to lack of funding for proper switches needed (netonix)
I have not but that is interesting for sure. If you try them let us know how it works out!
W
I just ordered those a couple months ago for some ubiquiti antennas, they worked fine.
Yeah, that’s what I need them for. It’s hard to find a 12v switch that can do both 24/48v PoE, unless you buy a netonix switch, very costly.
I am fond of the Ubiquiti TS-8-PRO; I think it was an excellent switch for mixed voltage applications, and I still have several of those in service, plus a spare. Some used ones on Amazon are priced fairly. If unmanaged is okay, the Wi-Tek switches are good with a broad operating temperature; they also have a DIN model. https://www.wireless-tek.com/product.php?lm=25
Works great. The current setup shows less power consumption over how it was before. So no issues.
