Blocking QUIC on Unifi
I was curious about something. I remember a video Willie did on blocking QUIC on Unifi.
Since then the zone based firewall came along and I am not so sure how to do it.
I was able to Block it in the settings-security-simple app blocking.
But I seem to remember that you set a policy in the firewall itself as well. Saw some instructions on a web page that says go to settings-routing-zone based firewall, but it has policy based routes instead of zone based firewall.
Not sure if I need to block QUIC or not, but I do sometimes like to fiddle with stuff like that to learn more about the network settings.
Anyone know?
hi and just a question
Why do you want to block it ?
A google search seems to indicate that there is nothing wrong with
such connections.
So why ?
Thanks
It is considered a security vulnerability by some.
It’s UDP based and can bypass some security protocols. In some environments it’s suggested to block it.
