Cat6 coupler cable extension
Hello, I just order 100 pieces directly from the manufacturer in China.
Currently using coupler in the attic to extend cables.
Interesting. Is it punched down inside each half?
Yes, it is toolless. For .75ea, worth a try.
Any chance I can buy a few of these from you for testing?
I will ask the rep I am communicating with.
I will send some to you for free, when I receive them in Feb.
FYI, Alexia from HY-Connect will contact you directly.
Thanks Alonzo, we got hooked up!
W
Great, Let us know your opinion of the HY-Connect products
