Cloud Controller for remote site
We will be moving within a few weeks but the process will take 5-6 weeks to complete. I run a UDM Pro at home and have a couple of spare access points.
My plan is to initially run a cloud controller with the spare AP’s, and my question is this.
Do I need a physical machine at the remote location to log into the cloud or do I just plug the APs into the LAN ports on the remote router?
I’ve already run the set-inform command on the APs and they’re adopted into the new site.
Thanks for any advice
If the APs are set to your cloud controller then yes all you should have to do is plug them up into the lan ports.
Thank you. I appreciate the response
