I have mainly been using MikroTik for all my networking, but recently became interested in Grandstream.
So, my question(s) are: If the GSS60xx series do not support OSPF, but Grandstream has some Layer 3 switches and I want to setup a GCC6011 for internet access. How do I configure OSPF on the switches and yet be able to get Internet access to all the VLANs from the GCC?
I am pretty sure there is a simple answer to this, but it has been so long since I have had to do this that I have forgotten.
Thank you to anyone that can help or point me in the right direction.
Typically what we’re going to do is create a small network between the GCC and the main switch that’s handling your router. We’ll make the GCC the gateway of last resort and it will have static routes back to the switch. Something like this:
Thank you for that information. I was thinking it was simply setting up a static route back to the GCC, but couldn’t remember for sure. Amazing how easily you can forget the simple stuff when you don’t use it very often.
