I have put together what I could find as the closest components from each vender to replace my Netgear Orbi 3 Satellite system with a couple of un-managed switches. The GS package is significantly cheaper and appears to provide similar functionality. The GWN7822P switch is a big money saver, but is also new and I can’t find any feedback.
If I go with GS am I missing any features (my network load is listed below)?
My proposed setup is as follows:
GS $700 Total (for items below)
$80 GWN7003 Gigabit Router
2x 2.5 Gigabit SFP ports and 9x Gigabit
Ethernet ports
$410 GWN7822P Layer 3 Multi-Gigabit Network Switch
4 10G SFP+ Ports, (16x 1G, 8x 2.5G) POE +,++
$210 2x$105 GWN7665 WiFi 6E AP 2x2
Unifi $1310 Total (for items below)
$130 Cloud Gateway Ultra (Router?)
$800 Pro Max 24 PoE
Layer 3 switch
(2) 10G SFP+ ports,
(16) GbE ports including (8) PoE+ and (8) PoE++,
(8) 2.5 GbE PoE++ ports
$380 2x$190 U7 Pro 2x2
Omada $1460 Total (for items below)
$400 ER8411 VPN Router with 10G Ports
Needed since switch is only L2+
$720 SG3428XPP-M2 L2+ Managed Switch
4× 10G SFP+ Slots
16× 2.5G PoE+ Ports
8× 2.5G PoE++ Ports
$340 2x$170 EAP772 WiFi 7 2x2
I am moving and will have:
Synology NAS w/BU NAS
Home Assistant w/ various IoT devices/sensors
10 IP Cameras
35 WiFi - Matter Leviton switches/dimmers (no WiFi polling)
6 Hardwired TVs
1-2 Desktop PCs
3 Wireless PCs
2-3 APs (it’s a Quad level house)
I wanted some future proofing with 10GB lines between my desktop and NAS and between the two NAS’s.
GS does not have WiFi 7 APs (may change on the 19th) so I went with 6E but Omada and Unifi only have high end 6E APs so WiFi 7 was cheaper.
Since my admin vlan on the 10GB line will be inter vlan I had to choose a higher end Omada router since the comparable switch is only L2+
I am not sure if each component from each vendor is comparable so any help or advice would be appreciated!
