GWN7660EM first look
Just got a few of these new extenders in. Pretty easy to set up. Plugged in with ethernet first, added to gdms and let it sync up. Made sure mesh was turned on and removed ethernet cable. Took less than a minute for the light to go blue and now working great.
Thanks for sharing your experience. I am curious about it and waiting some need to arise where I can test it.
Maybe a little to bulky? TP-Link ones are more discrete.
It’s pretty small, doesn’t take up much room and there is still space on a normal outlet to plug something else in. A little larger than a Glade Plugin. Set up one yesterday for a client, using it in mesh mode with a GWN7625.
These look so sweet. I’m glad that Grandstream is beefing up this portfolio. I can’t wait to get my hands on these and also their upcoming NAS.
Wow these are small! Thanks for the info on these. But are limited to 7062 or 7062(E)?
No, not limited to the 7062s but might be easier to pair with them. If you add them to GDMS and mesh is enabled, they will sync up to any of the Grandstream APs.
Awesome man! Thanks for the info
