Has anyone used this Cat6 Punch-Down Keystone Jack with LED with the Intellinet LED Ethernet Port Detector Tool?
That looks pretty cool. If you do try it, send some photos.
I saw these led jacks is custom home build. Trying to justified the purchase
Will post a pics if I purchase.
These are awesome! Iām still waiting for the vendor you were hooking me up with on other projects to send over samples.
These are fantastic, thanks your sharing! Can you change the LED color on each jack or have to order the color you want?
You can not change the light. When my house was built, the security company ran the network cabling. The jacks were labeled wrong and crappy 5e jacks used with cat6 cable.
