Outdoor AP Question
Can we use directional antenna’s with Grandstream outdoor Ap’s. I have a warehouse project that I will be designing/installation and configuration. Don’t have the plans yet, should be receiving them on Monday. So I don’t really know how high the ceiling or shelving will be. I am just pre planning. Or do I need to look at another manufacture?
So talked to support and they suggested the 7670LR which has internal antennas. 2.4 is at 90 degrees and 5g is at 35 degrees. The internal is selected in Ap’s webpage. Just an FYI
Let us know which antenna’s you do use and how well they work or don’t.
Will do, I will be testing this weekend.
