Does anyone here have any experience with setting up smart switches on the IoT network and set the network up so that you can still control the switches in Apple Home from the default network?
I found a YouTube video that explained how to do it, and then there is an article that updated the info since the zone firewall came about. It involves putting the IoT network in the internal zone but creating two or three rules that in effect allows the default network to punch into the IoT network and allow for return traffic. Another rule pretty much blocks anything from the IoT network to initiate any traffic back to the default network.
Here’s a link the the article and was wondering if it’s smart to include IoT in the Internal zone.
Apple home pretty much requires anything that is controlled has to be in the same default network.
I would like to be able to do this if it’s safe, and I tried to set it up but still couldn’t get the smart plugs wo work, and I imagine I probably did something wrong. Definitely would like to get it to work if it’s safe to do so because I don’t like having my smart plugs in the default network since they are insecure and prone to hacking.
Here’s a link to the article that explains how to do it and it’s not too complicated.
https://terrywhite.com/unifi-iot-vlan-firewall-rules-for-apple-matter-users/
Thanks for any insight you can bring to the subject.
