Is there a way to set a switch port on a GWN switch to access, rather than trunk, using GDMS.cloud? Meaning without logging into the switch itself?
I looked everywhere and can not find the option to do it from gdms.cloud.
I thought it was just me! Okay thanks for verifying.
Acutely you can, go into the switch, edit port and define vlan. I believe this does make it access with correct pvid. I usually just log in and do it, because I usually configuring before going onsite. I’m old school.
Thank you! In my testing today that doesn’t actually do anything but change the native VLAN to the port, which defaults as a trunk port. I am just going to stick with logging into the switch for now.
Yeah I kept trying that too but on the switch itself it stays as trunk. I was able to adjust it via ssh but that’s more time consuming IMO.
Like I said I like configure everything manually that way I know its done correctly. You can always submit a ticket with Grandstream to let them know the issue? Does seem too hard to add another line under ports vlan to select if trunk or access.
I agree, I prefer to do most things manually.
