Just wondering if any of you guys are using 8.6x-8.7.11 firmware on PmPT and or CPE equipment?
I have my entire network still running 8.5.12. The reason for this is because the Rocket 5ac Lite & Prism PmPT will randomly skip or change frequencies for no apparent reason after 24-48 hour, it causes havoc with the CPE and the customer. With 8.5.12, I do not have this issue, and also for my customers that have been a long time customer, meaning the CPE was installed as it is now, and has never moved, when changing firmware, I would see a drop in connectivity, for example if the CPE is connected at -65 -65, after upgrading to 8.6, 8.7.x the connection will normally drop down to -72 -72’ish. Anyone else ever dealt with this?
