Ubiquiti uisp store?
How do you access the UISP store on Ubiquiti’s website? store.ui.com is only Unifi, I cant seem to find a link to the UISP side… ?? Am I over looking something?
So it seems like they have completely separated the stores. you now need to go to
and if you lick on store, it takes you here:
Yup – this is the answer I got from my contact too – they are mid stroke on redoing the stores.
uisp.com is a real thing now.
Yeah – they are definitely putting some distance between the lines. Lots of EdgeMax gear out of stock and I wonder if it will actually return or if they are going to continue to try to simplify the Edge line. They told me it wasn’t dead and they are moving forward with it – but they didn’t say it wouldn’t be a “simplification” of the devices and interfaces.
