We are tying to move our network from Bridged AircubeAC’s to Router Mode AircubeAC’s . The thing we see is that if you make this change in the GUI of UISP, You pull up the device then settings and in old device detail, then change to Router Mode under Networking, the DHCP server is NOT turned on. This shows customer’s connecting but it is just the devices asking for DHCP addresses and never being connected. You must access the device GUI via IP address, and then change to Router Mode on the Device GUI. Then the DHCP server option shows that it is turned on ,and you are allowed to enable Management Remote access ,Turn NAT on and ect. Anybody else have this problem? #AircubeAC
I’ve had similar issues with them, older firmware was the issue.
